Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
Reload this Page >
Need help with EP J3 Electricub
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 05-29-2013, 06:36 AM
craigm1
Default Need help with EP J3 Electricub
I have Great Planes J3 Electricub with the standard motor/gearbox set up. I was looking to put something else in it to give it just a bit more power. Any suggestions on what to put in this plane?
SPECIFICATIONS
Stock Number: GPMA1153
Wingspan: 41 in (1040 mm)
Total Wing Area: 269 in² (17.4 dm²)
Wing Loading: 7.5 oz/ft² (23 g/dm²)
Weight: 14 oz (395 g)
Length: 29.5 in (750 mm)
Includes: 280 motor, 3.5:1 gearbox, ESC, 8-cell 9.6V 600mAh NiMH battery and 10x7 prop
Requires: 3-4 channel radio w/2 micro or NanoTM servos and charger
Here's a link to it on the Electrifly site: http://www.electrifly.com/discontinued/gpma1153.html
Old 05-29-2013, 08:15 AM
flyinwalenda
flyinwalenda's Avatar
Default RE: Need help with EP J3 Electricub
Couple of things to consider. To increase the performance you would want to go to a brushless set-up using lipo batteries. That would mean removing the gearbox set-up and making or buying a mount to install a brushless motor. Then add an ESC and a lipo battery . then you would need a charger capable of charging a lipo battery.
So the first question would be;do you have any electrics running lipo packs and a charger capable of charging them ?
If so then you would be looking at spending around $60-70.00 on the low side to equip the plane with a new motor, ESC, LiPo battery and accessories. If you needed to buy a charger then add another $30.00 + for a basic "4-button" multi-charger.
I would say something like a 2805 brushless 1300kva (Blue Wonder type)motor, 18 amp ESC, a 11.1v 1300mah LiPo , and a 9X4.75 prop.
Old 05-30-2013, 04:41 PM
blvdbuzzard
If you look down thee is a thread about an elictricub. This is the power system I have and the one I recommended. Runs an APC 12X6 prop and have a lot more power and flight times. If you read the other thread, I laughed about the cleared work bench comments.
They are out of stock right now. They come and go fast.
Battery
http://www.hobbypartz.com/98p-25c-2200-3s1p.html
Motor
http://www.hobbypartz.com/96m601-big...20-1100kv.html
ESC
http://www.hobbypartz.com/07e06-proton-60a.html
http://www.hobbypartz.com/07e-flyfun-60a.html
Here is the link to the other thread. It may answer some of your questions.
http://www.rcuniverse.com/forum/m_11434397/tm.htm
Buzz.
Old 05-31-2013, 05:17 AM
craigm1
Blvdbuzzard, thanks for the pointer but this is the smaller Electricub - only 41 inch wingspan.
Old 05-31-2013, 05:18 AM
craigm1
Brian Ray, thanks for the info...I'll poke around with those specs and see what I can come up with.
Old 05-31-2013, 08:06 PM
blvdbuzzard
I saw the electri cub and ran with it.
For something that small. You could go with something like this.
ESC
http://www.hobbypartz.com/07e04-proton-30a.html
Motor
http://www.hobbypartz.com/86ma70-2215-800kv.html
Battery
http://www.hobbypartz.com/98p-25c-1000-3s1p.html
Servos
http://www.hobbypartz.com/exi-servo-s0820.html
Buzz
Copyright © 2021 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
