Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
Reload this Page >
What does the formula tell you?
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 06-14-2013, 01:47 PM
c130nut
Default What does the formula tell you?
I have been out of electrics for a few years and am trying to remember what a particular formula tells you. I think it was the amp rating of the battery times the C rating then divide by 1000. Like 2200*30C= 66000 > 66000/1000=66 Is this the max amps that battery can discharge or the ESC rating I need?
I just cannot remember, but I am trying to re-rig an old Great Planes Siren hotliner.
Old 06-14-2013, 02:12 PM
guver
My Feedback: (325)
Default RE: What does the formula tell you?
C means "capacity" and the number is a multiplier. It can a number of currents (amps) such as recommended charge rate , max charge rate , burst discharge rate , max constant discharge rate, ect. Most times when we use the phrase "C rate" we are describing the maximum constant discharge rate by the cell manufacturer. I think that's what you're after and those ratings many times are grossly inflated when using a pack in a plane.
For a 2.2 pack that is listed as a 20C it is then 2.2x20=44 amps.
For a 2.2 pack that is listed as a 5C it is 2.2x5=11 amps.
Old 06-14-2013, 02:32 PM
c130nut
Ahhh... I found it...
A 2200mAh 10C battery is rated to be discharge at up to 22A (10 x 2200mA/1000) and the same size 12C battery would be good for 26.4A (12 x 2200mA/1000).
http://www.rcgroups.com/forums/showthread.php?t=739069
Thanks for the info! I knew I had seen it somewhere before.
Bill R.
