Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
Reload this Page >
Calibrating an ESC with Transmitter.
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 02-04-2015, 04:52 PM
Ed
Default Calibrating an ESC with Transmitter.
When calibrating a new ESC with a Transmitter, and going from Hi throttle to Low throttle after plugging in your Rx, is it necessary for the motor to be plugged in ? I also assume that the throttle trim should be set to neutral, or centered ?
Ed
Old 02-05-2015, 05:07 AM
Rodney
You want the throttle trim to be FULL down. If you have to reverse the throttle direction after the first bind, then be sure to rebind after changing it so that the fail safe will be "throttle off".
Old 02-05-2015, 12:48 PM
Ed
Thank you Sir, and no motor needs to be plugged in ?
Old 02-06-2015, 04:45 AM
Rodney
I've never tried it without the motor being plugged in so can not answer this question. Why would you want to anyway, after all that is what you are using the ESC for and you need to know which way the motor is turning. If it is turning in the wrong direction, you need to interchange any two of the three leads between the ESC and the motor. It is best to have the prop off for initial setup in case it turns on wide open the first time you plug the ESC and battery together.
Old 03-28-2015, 12:03 PM
ArcadeAir
ArcadeAir's Avatar
I have always had my motor plugged in when calibrating the esc... It is a good idea to remove the prop though.
