Setting up a giro from other plane
FL
So I finally learned to fly rc planes by scratching building out of foam. One of the nice thing about foam planes is when you crash you can usually use the electronics for another plane. Well I've been flying a RMRC Recruit for a while not. I've beat the hell out of it and the air frame is ready for the trash. I bought a replacement airframe and swapped over the gyro and receiver. The motor and servos were included with the new plane. So I connect everything up but I am wondering how do I ensure the gyro is working correctly. With the plane in my hand and powered on I initialize the gyro. Now when I tilt the plane to the left (left wing down) the aileron goes up. Same thing happens on the right side. But when I tip the nose up the elevators go up too. If I tip the nose down the elevators go down. Is this correct. It seems backward to me. All control surfaces are working fine with stick input. It's the gyro I am not sure about. Don't want to maiden and dive into the ground.
