Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
Reload this Page >
Keeping a prop attached to the plane
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 05-28-2007, 05:01 PM
Hatty
Hatty's Avatar
Default Keeping a prop attached to the plane
What ways do you use to keep your prop attached to your prop saver? I lost my 4th prop today and I've had enough. I have tried o-rings and orthodontics rubber bands and they don't work well. Am I missing something? I use an AXI 2212/20 with an APC 8x4E. And don't tell me not to use a prop saver. My plane doesn't have landing gear and I'm not going to make landing gear for it.
You have any tips?
Old 05-28-2007, 06:49 PM
pilotpete2
pilotpete2's Avatar
Default RE: Keeping a prop attached to the plane
With no landing gear why not go with a folding prop
Pete
Old 05-28-2007, 08:48 PM
Hatty
Hatty's Avatar
if you point me to where I can buy a 8x4E APC folding prop then I will definitely do that.
Old 05-28-2007, 09:02 PM
jdetray
jdetray's Avatar
Hatty -
I've seen it recommended that prop savers not be used with power systems over about 100 W. Beyond that, many people move on to collet-type prop adapters.
It may be that rubber bands and o-rings can't take as much power as you are asking of them.
- Jeff
Old 05-28-2007, 09:10 PM
jzrf6c
Here's a trick than may help. Don't go to full throttle fast. The torque will most often snap the O-ring or most other "prop saver" retainers.
Old 05-29-2007, 03:43 PM
pilotpete2
pilotpete2's Avatar
Check out Hobby Lobby, they have both Graupner and Aeronout folders, APC not in that market.
Pete
Old 05-29-2007, 04:20 PM
trevormatney
I had this problem, and if there is room to put a second o-ring on it will possibly solve the problem. My first electric plane had a Rimfire outrunner (22-1000) on it, and my first flight the prop flew off. After a rough landing, I popped 2 o-rings on, and have'nt had a problem since. Good luck!
Trevor
Old 06-01-2007, 10:55 AM
Dr Kiwi
Landing Products (APC) do make an 8x4 folder: http://www.apcprop.com/cgi-bin/store...c=6a&product=+
ID:	695404   Click image for larger version
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service - Do Not Sell My Personal Information
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
