Go Back  RCU Forums > Electric Aircraft Universe > Electric General Discussion
Reload this Page >
Help me get my electric system operational
Electric General Discussion General Discussion forum about rc electric related aircraft, accessories, flight, tips, etc.
Old 07-31-2007, 09:34 PM
moreynj
Default Help me get my electric system operational
I purchased a brushless motor, a ESC for brushless, have LIPO, etc. Doesnt work. Following instuctions on ESC, it should beep-beep first at full throttle, etc, etc to adjust. When hooked up to LIPO, does nothing. Power is going thru ESC to receiver ok. When I hook up the motor, it "pulses" but doesnt turn. The throttle on my radio has no effect on setup. LIPO is fully charged.
My hookup is as follows. LIPO - (deans plug) - ESC [red and black wires]
ESC [3 red wires] to motor [3 wires, red-yellow-purple]
ESC futaba plug to throttle input on receiver
Old 07-31-2007, 11:21 PM
jdetray
jdetray's Avatar
Default RE: Help me get my electric system operational
You won't hear any beeps unless the motor is connected. The ESC uses the motor as a "speaker" to produce the beeps. When testing, be sure to do it with the motor connected but no prop on the motor.
If your transmitter is a Futaba, try reversing the throttle channel.
Always turn on the transmitter before connecting the battery to the ESC.
Do the servos work?
If you want additional help, tell us exactly which equipment you are using, and hopefully someone will have specific suggestions.
- Jeff
Old 08-01-2007, 07:49 PM
Walt Thyng
My Feedback: (9)
Moreynj,
you may have to swap the motor esc wires around to find a combination that runs. I've had a couple of motors do the stuttering thing on me and that solved it.
WT
Old 08-01-2007, 08:39 PM
jzrf6c
Most of the time I've found the cause of "motor stuttering" to be a bad connection on one of three motor windings. Sometimes youd may not have good clean connectors and moving the plugs around seems to make things work. What actually happened was. most likely, was the you scraped the connector and then had a good connection.
Old 08-02-2007, 08:01 AM
Walt Thyng
My Feedback: (9)
Psosible, but not likely. I'm very fussy about my Power Pole connectors.
WT
Old 08-02-2007, 08:04 AM
moreynj
Got the motor running. AOK now.
Old 08-02-2007, 10:32 AM
jdetray
jdetray's Avatar
ORIGINAL: moreynj
Congratulations! What was the problem?
- Jeff
