splicing a 10 gage wire down to a 12 gage
I picked up some Turnigy lipos and they come with 10g wire on them, my ESC and most of my battery have 12g wire on them and I use ES3 connectors. My question is what is the best way to get my 10g wire down to 12g (since the ES3's can only handle 12g, and I am not worried about overheating the 12g wire).<o></o
<o></o
The way I look at it I have 2 options to do this,<o></o
<o></o
1- splice the 12g to the 10g and solder them together and insulate the joint (this would just give me 2 joints, the spice and the ES3 joint)<o></o
2- use a dean or ES5 (big enough for 10g) on the battery then create a jumper from the Dean or ES5 with 12g wire to the ES3 connector (this gives me 3 solder joints)<o></o
<o></o
I am open for ideas! Except for putting a gas engine in!!<o></o
<o></o
Thanks for any input!!<o></o
<o></o
Bob<o></o
I think what I will do, is jsut move everything to dean connectors this allows me to solder any wire directly to the connector and gets rid of the splices or jumpers
My ESC has an arming switch, just need to get rid of the useless turingy conectors!
thanks all this helps
Also i figured out if I "Tin my 10 gauge wire and then slot the tinned end with a dremal tool I will have a very good srface to solder my 10 g to my dean!!!
Thanks!!!!
