Finesse 1.20 patern plane Electric conversion
I bought this Finesse 1.20 pattern plane. I am going to restore it and after seeing the latest AMA issue, I am wondering if there is a electric motor that would power it. The plane requires a 1.20 four stroke, what motor would I need and also how would I setup the motor with a controller for the motor, if it can be done.
RE: Finesse 1.20 patern plane Electric conversion
You want something in the 8S or 10S range ... you want to turn something like an 18x10. You can look at a motor in the 250KV (8S) or 230KV (10S) range ... see what Sebart recommends for the Wind S 110 ... that is a good baseline. :) I am running a Scorpion 4035-250 on 10S for my Wind S 110, its best on 8S actually, a slightly lower KV motor would be nice got 10S.
