Hobby king discount buddy codes
60A ESC: http://www.hobbyking.com/buddy.asp?c...E-7DCD1D485011
3.5mm gold esc wire connectors: http://www.hobbyking.com/buddy.asp?c...F-8D25AADF4717 1 meter of 4mm black heat shrink tube: http://www.hobbyking.com/buddy.asp?c...B-17A8B54EF296 brushless motor shaft; if you then pair this with the motor it goes to you can get the motor for $17: http://www.hobbyking.com/buddy.asp?c...2-5E42EBE9293F EC5 5mm battery connectors for 120+Amps: http://www.hobbyking.com/buddy.asp?c...0-BC2A4220C044 Save money with these links. |
RE: Hobby king discount buddy codes
Anything on backorder usually is in stock soon.
Just my luck as i put in an order early last week for most of what you have listed there apart from the last two,i'll remember to look on here before i put my next order in,;) still thanks for sharing the codes even if i couldn't use them i'm sure others might.:D
