RCU Forums
-   Electric General Discussion (https://www.rcuniverse.com/forum/electric-general-discussion-106/)
-   -   Setup for brushed motor? (https://www.rcuniverse.com/forum/electric-general-discussion-106/11599836-setup-brushed-motor.html)
shd3920 06-02-2014 06:05 PM
http://www.ebay.com/itm/GRAUPNER-SPE...item19ed891c2f
1) What amp brushed speed control would I need with this motor?
2) What size battery pack for both NiMh and Lipo?
3) Anything else needed for the motor? Says it is already geared.
aeajr 06-03-2014 07:29 PM
That is a speed 400 motor. Anything over 15 amps should be adequate. 20 to be safe. Motor should actually run about 10 to 12 amps.
Side of box says 7-9 cells which would be NiCd or NiMh cells. That would be 8.4 to 11.8V. 2S to 3S lipo should work.
I am going to guess a 9X7 prop.
I would use a watt meter to insure that you are not pulling more than about 12 amps or you will burn the motor up pretty quickly.
I would recommend using LiPo batteries. Much lighter than NiXX.
This will work for 2-3 cells lipo
http://www.hobbyking.com/hobbyking/s...arehouse_.html
I don't know what kind of room you have in the plane but I would suggest something in the 1200 to 2100 mah range, depending on the plane and the space available.
