SAB Avio KR84 Tortuga - Freaky Fast
"IT's TORTUGA TIME !" That's what we heard as our Italian friends from SAB Avio bungee and hand launched their Tortugas into the air to give a hot demonstration of the speed of the new Tortuga from SAB Avio.
TORTUGA is a Full sandwich Fiber glass / Airex Fuselage (made under vacuum). - Super rigid, ready for High speed. - All parts are already painted. - Horns are already mounted. - Super-fast assembly, in 2 hours the model is ready to fly. Specification: Wingspan: 84 cm Length: 81 cm Weight RTF: 1.55 KG Wing area: 2400 cm2 Recommended setup: Channels: 4 2 x mini wing servos 30 x 10 x 30 mm 1 x micro servo 12 x 23 mm Flight battery: 6S — 2600 / 3200 mAh Motor: 2200 kV, 28-36mm ESC: 100-120A-ESC, Propellor: 5x5 Max motor size: 36mm diameter Max motor weight: 150 grams Battery Compartment: 55x45x200 mm |
anyone still flying their electric or turbine Tortugas lately?
