Connecting DYS USB Linker to DYS XS30A
Hello,
I'm unable to connect DYS USB Linker to DYS XS30A. These are the steps I made: 1. Downloaded BLHeliSuite 16.6.14.9.0.1 2. Installed the Silabs driver. 3. Connected the USB linker to a USB port on my PC. 4. Connected the servo lead from the XS30A to the USB Linker - such that the white wire goes into the signal probe and the black to ground (the middle wire is missing). 5. Chose #4 under the "Select ATMEL/SILABS Interface" 6. Chose the correct COM port and port speed. 7. Applied 12V power to the XS30A. 8. Pressed the "Connect" button. I waited for 10 seconds and got the message: Stk500v2 connection to ESC at COM5 failed! (Error: "CMD_SIGN_ON: read => Timeout (no answer) Please help. |
