RCU Forums
-   Electric General Discussion (https://www.rcuniverse.com/forum/electric-general-discussion-106/)
-   -   ParkZone ESC With Futaba RX (https://www.rcuniverse.com/forum/electric-general-discussion-106/11669883-parkzone-esc-futaba-rx.html)
AllModesR/C 09-21-2019 01:36 PM
I bought this plane and it has a Spectrum receiver and I don't have the transmitter. I have a nice 72mhz Futaba system but it isn't send a signal to the ESC to power the motor.https://cimg4.ibsrv.net/gimg/www.rcu...96db299e98.jpg
https://cimg1.ibsrv.net/gimg/www.rcu...87a3ea6b4f.jpg
ron_van_sommeren 09-22-2019 08:46 AM
Have you tried a servo on throttle channel instead of an ESC?
Futaba transmitters must have their throttle reversed for ESC use.
Prettig weekend ;) Ron
• Without a watt-meter you are in the dark ... until something starts to glow •
e-flight calculatorswatt-metersdiy motor tips&tricksCumulus MFC
AllModesR/C 09-22-2019 12:14 PM
Yes, today I tried the elevator servo and it won't spin when input is given. I tried plugging in my JR system and the same problem.
ron_van_sommeren 09-23-2019 01:11 PM
Originally Posted by AllModesR/C (Post 12551943)
Yes, today I tried the elevator servo and it won't spin when input is given. ...
How did you power receiver/servos?
Have you tried other outputs on receiver?
Do you see/measure power on receiver outputs?
https://cimg8.ibsrv.net/gimg/www.rcu...97324dd055.gif
https://cimg0.ibsrv.net/gimg/www.rcu...d26f76594f.gif
Vriendelijke groeten ;) Ron
e-flight calculators watt-meters diy motor tips&tricks Cumulus MFC
AllModesR/C 09-25-2019 04:27 PM
Thank you the response. This is a photo of a Futaba servo plug on the left which works fine and the mini servo that's in the plane. The red is in the center on both and the negative is on the same side, just brown in color on the Parkzone plug. As already mentioned, the servo does twitch plugged in. I tried all the ports on the RX and the same thing. No movement.
https://cimg7.ibsrv.net/gimg/www.rcu...2e04b040b1.jpg
https://cimg2.ibsrv.net/gimg/www.rcu...b4d02495a4.jpg
AllModesR/C 09-25-2019 05:46 PM
I made some progress this evening. I managed to make the throttle and aileron servo(s) work. It appears you need to plug the speed control plug into the RX and wait for a beep. I am not familiar with electric planes so this was a learning experience for me. Sill the elevator servo will not move.
ron_van_sommeren 09-27-2019 04:16 AM
2 Attachment(s)
Originally Posted by AllModesR/C (Post 12552621)
... Sill the elevator servo will not move.
Transmitter settings? Servo throw reduction active, dual rate active, mixers active?
Elevator servo okay? It moves on an aileron output? Aileron servo moves on elevator output?
... I am not familiar with electric planes so this was a learning experience for me. ...
Some well-structured reading for rainy/windy days, including two e-books, and some handy e-tools as well. Will save you, and us Attachment 2265308 a lot of questions. Notably the 'what went wrong?' kind of questions Attachment 2265309 Will also prevent you from burning up several controllers and/or motors and/or battery:
E-flight primer and tools
And pleasepleaseplease, do your RC equipment, wallet, ego, battery, controller, motor, house/garage/car a big favour ... get a watt-meter. It will more than pay for itself, will save you at least one fried motor and one fried controller. Will also help you finding the best setup.
Keep battery-/-watt-/multi-meter wires short!
too long wires batteryside will kill ESC over time: precautions, solutions & workarounds
