Giant Heinkel 219 by Dave Platt
I'm sorta new to electric: 30+ years in large warbirds, however. After dinking around with some foamies, then "training" on the Otter you see in the background, I teamed up with my buddy Lynn to electrify this 121", 54 lb beauty built by Dave Platt some 10 years ago. I suspect he gave up on it because he couldn't fit a big enough piston engine in the cowls!
All is going well, but I am doing thorough testing on all components before I fly a museum-quality masterpiece Engines have come down to Dualsky 6000 vs AXi5345 and I've put them both through a lot of props on the stand. Using Castle Edge HV160's and 7.7 amp-hour TP 12S lipos. I really like the way the AXi swings a Xoar 20x12 prop for > 8 minutes and I have experience with those props, that rpm range on some big gassers: CBA-38 and Ziroli P-61 But I'm also measuring motor casing temps, and the AXi 5345 alway goes to about 130 F and stays there for most of a mixed high throttle run. Is that OK?? I started with the higher engine timing set-up advised by AXi: 20-25 degrees, backed off to 5 degrees at recommendation of Castle tecchie and a knowledgeable friend, didn't seem to make much difference Help?? https://cimg7.ibsrv.net/gimg/www.rcu...3dda7eca60.jpg |
42 Attachment(s)
Not an answer to your question, but since it's a twin model ...
Too long wires batteryside will kill ESC over time: precautions, solutions & workarounds - RCG Contents
Vriendelijke groeten, en wees voorzichtig ;) Ron • Without a watt-meter you are in the dark ... until something starts to glow • • e-flight calculators • watt-meters • high power motor tips&tricks • Cumulus MFC • |
Thanks for a very thorough summation
I wrassled with a lot of that with big-twin planning last fall and made a critical strategic decision to install the motors completely independently, which obviates concerns about long wires, but of course raises concerns about differential power outputs and/or battery rundown. so far in testing on the Otter and the big motors, side differential has NOT been a problem. But my lipo’s are relatively new. My prop testing has been aggressive: 2 and 3 blade Xoars, Mejliks, Biela’s, Varios from Germany. Favorite so far is Xoar 20x12’s 2B. Getting peaks > 7,000 rpm, run times up to 9 minutes at high mixed throttle. Still concerned about the AXi’s (which chew up less battery) heating up to 130° and above at high throttle. No answer from Espirit Models. Could it be my 12S lipo’s? AXi package insert says 8-12S lipo’s, “10S ideal.” Thanks for your help. Experienced big motor guys MUCH appreciated Mark |
