RCU Forums
-   Electric General Discussion (https://www.rcuniverse.com/forum/electric-general-discussion-106/)
-   -   Returning to flying, need some current product knowledge (https://www.rcuniverse.com/forum/electric-general-discussion-106/11713935-returning-flying-need-some-current-product-knowledge.html)
fhm100 02-18-2025 09:56 PM
Hey folks. Been out of hobbies since middle 2000’s, went looking at ESCs and there are way more choices these days. I recently acquired a NIB Hangar 9 40 Cub with the included Power 46 out runner. It calls for a 60A speed control and I also got a NIP Common Sense RC 60A ESC. I looked them up and while CSRC is still in business, I didn’t see any ESCs offered.
my question is what about the ESC I have, would you trust it? If not what should I be looking at? would an 80A esc be a better choice, and what brand. When I was active, Castle Creations were the only real game in town.
I don’t plan to do much with a cub but fly around the pattern on nice days so I don’t need a high zoot or hot setup, just reliable equipment with a reasonable expectation of getting my plane up and back down should do it.
Thanks in advance for any and all advice, experiences, or opinions.
LLRCFlyer 02-19-2025 02:16 PM
2 Attachment(s)
The age of the ESC is not too important if the wiring is still good, i.e., not dried out or cracked. I would be more concerned about the ESC having a battery eliminator circuit (BEC) with sufficient amperage capacity to preclude brownouts, especially if using modern digital servos. Older ESC's often had linear (straight resistance) BEC's of questionable capacity. I would recommend an ESC with a switch-mode BEC capable of at least 6 amps for your purposes. Modern digital servos may have low average running amperages but they pull very brief but high peak instantaneous starting amps (essentially locked-rotor "stalled" current) which can damage the BEC over time, or cause low-voltage brown-outs (see attachment). Castle is known for high-end ESC's and are high priced... way over-priced for my needs. I have used several sizes of Hobbywing ESC's over the years and enjoyed good service from them... never had one cause a crash. The Hobbywing inventory includes some nice 60 and 80 amp ESC's. Here is a link to a suitable 60 amp ESC with an 8/20 amp (continuous/peak) switch-mode BEC which should serve you well.
https://www.altitudehobbies.com/coll...series-60a-esc
ron_van_sommeren 03-01-2025 10:29 AM
1 Attachment(s)
Originally Posted by fhm100 (Post 12815406)
... would an 80A esc be a better choice ...
No problem, at all.
... It calls for a 60A speed control ...
Power system derating
It is a wise practice to have some headroom built in. Motors and controllers run cooler, slightly more efficient too, and it gives some leeway should things go south a bit.
About derating motors, controllers, batteries, electronics in general:
