RCU Forums
-   Electric General Discussion (https://www.rcuniverse.com/forum/electric-general-discussion-106/)
-   -   Push rod attachment??? (https://www.rcuniverse.com/forum/electric-general-discussion-106/1526309-push-rod-attachment.html)
e-PSF 02-13-2004 11:39 PM
Greetings -
I am finishing my SS (first RC Plane) and am having a blond moment trying to connect the push/pull rod to the servo. this has got to be easy I Just cant see it!! Can someone point me to a visual resource? Thanks in advance. Scott
e-PSF 02-14-2004 02:49 PM
RE: Push rod attachment???
Ahhh Dubro....thanks!
Gklugie 02-18-2004 01:38 PM
1. If the end of the rod is threaded, simply screw on a Dubro nylon clevis.
2. In not threaded, and presuming you have enough length, put a "z bend" in the rod with a Dubro Z-bend tool. or pliers if you are careful
3. but a tap ( 4-40 ??), and cut threads into the end of the rod so that you can do step #1
Matt Kirsch 02-18-2004 03:34 PM
In a typical pushrod setup, there's an adjustable clevis on one end, and a Z-bend on the other.
For park flyers, Dubro EZ Connectors make it very simple. I would not suggest using them for primary control surfaces on anything but small park fliers.
You could also put Z-bends in both ends, but this requires a high level of precision, and does not allow you to make adjustments later. A variation on this method involves bending a large V into the pushrod along an open unobstructed section of the rod, then putting Z-bends in both ends. By widening or narrowing the V, you can adjust the length of the pushrod:
z----------v-----z
This should also be limited to small park flyers, because the V can induce some unpredictable flexing when used on a heavier airplane.
