Balsa to foam will work???
I TRIED THIS IN ANOTHER FORUM BUT RECEIVED NO FEEDBACK I HAVE BECOME VERY INTERESTED IN THE FOAM FLYERS EVER SINCE SOMEONE POSTED HOW TO BUILD A FOAM CUTTER. THIS SEEMS THE WAY TO GO TO SAVE BUILD TIME. MY QUESTION IS: CAN I TAKE PLANS FOR A BALSA PARKFLYER(LETS SAY A STAGGERWING) AND USE THE BASIC SHAPES,OUTLINES AND SIZES TO CUT A FOAM PLANE AND WILL IT FLY THE SAME AS THE INTENDED BALSA PLANE? THAT WOULD SAVE BUILD AND REPAIR TIME AND A LOT OF HEARTACHE. THANKS IN ADVANCE.
RE: Balsa to foam will work???
ORIGINAL: eetrapnoel CAN I TAKE PLANS FOR A BALSA PARKFLYER(LETS SAY A STAGGERWING) AND USE THE BASIC SHAPES,OUTLINES AND SIZES TO CUT A FOAM PLANE AND WILL IT FLY THE SAME AS THE INTENDED BALSA PLANE? Brad |
1 Attachment(s)
[quote]ORIGINAL: eetrapnoel
CAN I TAKE PLANS FOR A BALSA PARKFLYER(LETS SAY A STAGGERWING) AND USE THE BASIC SHAPES,OUTLINES AND SIZES TO CUT A FOAM PLANE AND WILL IT FLY THE SAME AS THE INTENDED BALSA PLANE? THAT WOULD SAVE BUILD AND REPAIR TIME AND A LOT OF HEARTACHE. THANKS IN ADVANCE. This foam thing works good for me, just finished a Kaos. I took plans and resized them for a 38" wing span. The prototype flies great, I'm making a new fuselage with some changes no hot glue this time all probond. Should be lighter first one was 20oz. And I have started a ugly stick. Its quite fun.:D |
| All times are GMT -8. The time now is 02:04 PM. |
