RCU Forums
-   Electric General Discussion (https://www.rcuniverse.com/forum/electric-general-discussion-106/)
-   -   Need help - Crashed my Electric multiplex (https://www.rcuniverse.com/forum/electric-general-discussion-106/1860656-need-help-crashed-my-electric-multiplex.html)
superange 05-31-2004 11:13 AM
Hiya.
Well i was out flying, finally got my plane in the air (Multiplex easy flier) - and it worked great.
Ofcourse i crashed a few times (!) but nothing happened, so back to flying..
until i accidentally *cough* turbo dived into the ground with full speed, and apart from nothing breaking, then all the plane does now is say "beep beep beep" - I think the sound comes from the engine.
I also no longer have ANY radio contact with the plane - any ideas???
stoneware 05-31-2004 06:26 PM
RE: Need help - Crashed my Electric multiplex
From my experiences it sounds like there is something out of whack with your motor. I've done lots of what you are talking about only my planes all have the prop out front...so far.
Check the alignment of the armature in the motor. Also make sure the front and rear of the motor are square to the armatue shaft. ie the bearings are not pinching the prop shaft.
ciao
superange 05-31-2004 06:34 PM
I will check that - however wouldnt the servos work still then?
Ill go tear it apart, and have a look! =)
