RCU Forums
-   Electric General Discussion (https://www.rcuniverse.com/forum/electric-general-discussion-106/)
-   -   Help..what does (https://www.rcuniverse.com/forum/electric-general-discussion-106/2210296-help-what-does.html)
bobbart 09-28-2004 05:18 PM
Help..what does
How big is 6mm compare to one inch?
What does this mean 9x7 ?
Bob
2, 3 and 4 bladed semi-scale props
Prop blades and Midparts
FS001 9x7 Single Prop Blade ..... $ 1.00
IN STOCK
FS101 Midpart 2 Blade Holder, 6mm ..... $ 1.00
IN STOCK
FS103 Midpart 3 Blade Holder, 6mm ..... $ 1.00
IN STOCK
FS104 Midpart 4 Blade Holder, 6mm ..... $ 1.00
IN STOCK
________________________________________
Complete 2, 3, 4 Blade Props
FS200 2 Blade 9x7 Prop Complete ..... $ 3.00
IN STOCK
FS300 3 Blade 9x7 Prop Complete ..... $ 4.00
IN STOCK
FS400 4 Blade 9x7 Prop Complete ..... $ 5.00
IN STOCK
David Cutler 09-28-2004 05:27 PM
RE: Help..what does
There are 25.4 mm in one inch, so 6 mm is about 1/4 inch.
9x7 is a propellor size. It means it's 9 inches from tip to tip, and it will theoretically move forwards 7 inches per revolution. (Imagine a bolt turning one revolution in a nut, and the amount it moves axially is the pitch)
'9' is called the diameter, '7' is called the pitch.
So, a 16x4 is 16 inches from tip to tip, and it will move forwards (theoretically) 4 inches per revolution.
-David C.
bobbart 09-28-2004 05:48 PM
RE: Help..what does
Thanks David
Bob
Flypaper 2 09-29-2004 08:58 AM
RE: Help..what does
Another way is to use 4 as a multiplier to convert metric. Gets you close. 6 mm times 4 is 24, or .240 ins = just under 1/4 in. as David says.
