E-filte P-47 motor ?
Okay, I'am back in the hobby again and I have to say it because of the latest brushless motors, Li-po battery's and the gain of flight time. Here's my ?s .... Has anyone compared the stock brushed motor that comes with the E-flite P-47 to the Brushless 450. I have 6 flights on the stock motor and I need to replace it. Is the 450 more powerful running the 10X8e prop ? or do I need to up it to a 480 BL motor ,TP3s2100 to have the same preformance the stock motor had. I plan on staying in the 400 aircraft size and would like to swap the set up to other aircraft in this cat. I have the Hi-maxx 2816-0890 outrunner in another plane and was woundering if this might be a good match up for the P-47 . Any other susgestions also. [sm=confused.gif]Thanks
RE: E-filte P-47 motor ?
ORIGINAL: Knowitall Is the 450 more powerful running the 10X8e prop ? I plan on maidening it early next week to prepare for some flying with buddies on the 25th. Always bad karma to maiden a new bird in front of friends :) If you're happy with stock, you'd be pleased with with the Park 400, I think. If you want a bit more power, the 450 is up your alley. If you're looking for good vertical performance, though, these aren't a match. I'll see if I can write a more coherent review after the maiden. |
For the review, I used the Park 450 outrunner and an 10x8 prop. Good mix between thrust and pitch speed.
http://www.rcuniverse.com/magazine/a...article_id=637 |
Thanks for the info, The unbalanced prop is probally the reason the stock gear box and motor didn't last. I did some more research and read the reviews (excellent reviews). I think I will get the 450BL. I like to stay around 400 size motor and the specs on this will allow a 20 amp ESC (I already have (3)BL 20-25amp ESC) and this will keep the price down when I swap out motors.
Next I think I will swap between the 450 and the Himaxx 2816-0890 to see the difference between them in the same plane. The specs are close to the same.:) |
Okay I got the Park 450 BL motor, and the preformance is better then the stock motor by far. I then installed the Himaxx 2816-0890 BL motor. There was even a little better prefomance and a 2 min. longer flight time. I have over 25 flights on this plane and I really like it even though it's a foamy. After my test I decided the Himaxx is worth the $7 extra dollars and I would recommend it for this plane. Here's what I'm using: Himaxx Motor, Tanic 3s 1550 11.1v Lipo, Phoenix air 25 ESC, Cirrus Micro 6ch rec and HS-55 Servos. My next plan is to lose the Y harness that works the ailerons and run 2 -12" ex and have them on diferent ch. so I can try flaperons.
| All times are GMT -8. The time now is 10:04 AM. |
