Help in finding the correct motor choice
All,
I am a newbie to E-Flight. I have acquired a model of a P-51 that I purchased at a swap meet. The plane had a small 2-4 oz fuel tank and a small engine mount. Looks like about a .19 size. The fuselage is 27 inches and the wing is 35 inches. I don’t know the weight but it’s pretty light, Balsa and monokote type covering. It has elevator and aileron controls. I would like to go electric but have NO idea what size motor to start with. I’m an experience pilot so I can handle some speed. I would also like to use an ESC? and LIPO’s. Can you guys suggest a good starting point? Web sites to look at motors, maybe a package deal. Is there some kind of chart as a guide? I’ve done some searching here but to be honest theres soooo much to sift through. Thanks |
RE: Help in finding the correct motor choice
Using a lipo you are probably going to want to go brushless. I have not ventured into the brushless realm as of yet, you will also need a brushless ESC if you go that way.
http://www.towerhobbies.com/electric/index.html check out this link, they have just about everything. I would imagine you want to go with something that is equivalent to a 480 or 540 brushed motor?? |
the hacker A30-28S would be a perfect match from what you have described, also you can buy it as a combo with a great controller like the Castle creations phoenix 35, the combo is at a great discount when you buy them together at this site; ($129.99)
http://www.nesail.com/detail.php?productID=3573 i bought my last combo from them, they are great. also i would get a thunder power 3-cell 1320 lipo (usually around $50 or so) the combo i listed above will give you a light weight, but very powerful plane. it should be able to climb straight up if you want it to. john |
| All times are GMT -8. The time now is 02:32 AM. |
