JR 9303 stryker setup
I'm trying to set up a 9303 in the f27c. I connected everything per the instructions but I can't get the ailerons to work properly, they are reversed and nothing I do is correcting it. Any hellp is appreciated. I'm using the 7 channel reciever from JR. Thanks.
RE: JR 9303 stryker setup
I think you need to set the model as a delta wing, flaperons. Otherwise use the reverse function. You using to outputs to the ailerons or one?
