RCU Forums
-   Electric General Discussion (https://www.rcuniverse.com/forum/electric-general-discussion-106/)
-   -   BRUSHLESS SPEEDCONTROLLER (https://www.rcuniverse.com/forum/electric-general-discussion-106/5299014-brushless-speedcontroller.html)
on the EDGE(540) 01-21-2007 10:09 AM
HI can anyone help me please i have bought a ripmax 25a xtra brushless speed controller and can`t get the throttle to work lower than half stick. It stops when it moves lower than half way and only picks back up when it is back over half way. I have a futaba 6exa and have messed with the EPA and TRIM settings and wiped the model memory and still have the same problem. Has any one else had this happen to them as any help would be great.
daveosoar 01-21-2007 04:30 PM
RE: BRUSHLESS SPEEDCONTROLLER
Where is the trim?
daveosoar 01-21-2007 04:35 PM
I'Ve just re-read you post - lower? Since you have a Futaba you must reverse the throttle action. Pull the lever to bottom, reverse the servo function, push up and it should work.
Dave.
on the EDGE(540) 01-22-2007 04:14 PM
hi i have tried it and its still the same so im thinking its a duff speedcontroller [:@] i think i will try another and see if i have any luck with that .
Thanks for the info cheers Paul.
