RCU Forums
-   Electric General Discussion (https://www.rcuniverse.com/forum/electric-general-discussion-106/)
-   -   Small park plane (https://www.rcuniverse.com/forum/electric-general-discussion-106/6217551-small-park-plane.html)
LynxStrife 08-09-2007 05:00 PM
Small park plane
Well after looking at what my flying fields would be, I would need something that can do small parks. I think the Aerobird might be a little on the big side but I dont know what is the size needed.
So my picks thus far are.
1.>Aerobird Challenger - EP
2.>Hobby Lobby Bellanca Decathlon 480 RTF
3.>hobby Lobby SoarEasy ARF Electric RC Airplane
what would you pick?
Sir Raleigh 08-10-2007 12:45 PM
RE: Small park plane
You didn't say what size your small parks are, but the Hobbyzone Super Cub can fly in a relatively small area of about 600' x 600'. Once you get used to it I'm sure you can fly it in an even smaller space. I've seen people fly one in about half that area.
LynxStrife 08-10-2007 12:52 PM
I dont know the size, but its a smaller park I seen people fly smaller planes at that location, And I got a elementry school yard not too far. And a place I do know where people fly smaller aircraft.
Sir Raleigh 08-10-2007 01:09 PM
The Super Cub is a rather slow flier. It could probably be flow in an area the size of a baseball diamond, although I don't you'd get much fun in that small of an area.
If your flying area is that small, I'd suggest looking at some of the very slow fliers such as the slo-v and slow stick type planes.
http://www.hobbyzone.com/rc_planes_parkzone_slo-v.htm (slo-v)
http://www2.towerhobbies.com/cgi-bin...&I=LXPCG4&P=FR (slow stick)
john canfield 08-12-2007 05:11 PM
Without a doubt, the GWS Slow Stick.
twmoody 08-12-2007 07:38 PM
I fly my Pico Stick in a park across the street and it is only 112' by 170' and is completely surrounded by trees. If it is dead calm I fly my Diddle bug or my new Cessna 210 there.
Tom Moody
Tommyr 08-17-2007 09:46 PM
ParkZone's Cessna 210 is a good idea! Small and flys in small fields. I'll hopefully maiden mine tomorrow!
Tom
TBPlayer 08-18-2007 01:10 PM
Two of my six planes will fly in very small areas without any problem:
1. GWS Pico Tiger Moth - 3 channel - R/E/T - a very relaxing, slow flying plane that's capable of simple aerobatics.
2. Lightflite "Bug" - 4 channel - A/R/E/T - http://www.lightflite.com/ - will also fly fairly slow, but it's capable of wild aerobatics.
-Phil
Tommyr 08-19-2007 08:36 PM
ORIGINAL: Tommyr
Tom
Parkzone Cessna 210 review
I finally got to fly the plane this morning! Perfectly calm air at my favorite 76 acre park 14 miles north from me. Piece and quiet! You don’t need THAT much room but I love that park.
The plane can definatelybe flown in a small area, 50x50 feet more than likely if you don’t mind a lot of turning. I wanted to make sure I had plenty of room. A basketball court would be a good place, small parking lots, school yards, etc.
My park has grass about 8 inches high right now and sometimes they let it go much higher. High grass is a GOOD THING with this plane as it cusihons the plane well if you nose her in. I fortunately didn’t have that happen, I just flare her in when it’s time. The plane IS VERY light and delicate. With care it’s not a problem at all.
I had charged 2 batteries last night. Flights with good throttle management last about 15-20 minutes. I fly at about 50% throttle most of the time once I have her at altitude. Batteries charge in about 20 minutes. The charger works very well and having it double as a stand for the plane is a nice touch!
This plane is a MUST HAVE! An absolute BLAST to fly.
I hand launched it as the gravel parking lot in the park is much too rough. Easy as pie! I flew her no higher than about 30 feet as I like to see my planes fly, not a dot in the sky.
I flew out 3 battery packs. I did get several glitches during the 3 flights. Several times the motor stopped, I was able to regain the motor on one or two occasions (using the throttle stick back and forth) just in time and slowly flared her in for a landing on 1 or 2 other times. I believe I got an “Out of range” set of beeps from the TX once and the plane came down after that. Range seems to be a couple of hundred feet.
Noise wise it’s not bad, mine seemed to get a bit noisier after the second flight, a kind of whineing sound but I can tolerate it. A bit of lube should stop it.
A very light breeze near the end of flight 3 let me play with doing harrier moves, letting her float to nearly a stop against the breeze. A LIGHT breeze I might add. The plane doesn’t like wind but a VERY light occasional breeze is not much of a problem.
A BIG Kudos to Parkzone for taking this plane on and making it available! This is a REALLY FUN plane. Bigger kudos to the makers of it!
