On/Off Switch
Who makes a good 15A switch?
RE: On/Off Switch
I don't know about 15 amp but I read where someone was using DPST 6 amp switch and parallel the contacts. He using it for much more than 12 amps. He says the rating is for a ac switched load and they can carry much more load. I am looking a buying some switch and do some testing for myself.
RE: On/Off Switch
yeah, that was Red, check this post
http://www.rcuniverse.com/forum/fb.asp?m=6388888 |
RE: On/Off Switch
Yuh that is it. I think I am going see if the local Source has any switchs. I was looking a switch at digkey I think that you had to pull the lever to change the switch positions.
| All times are GMT -8. The time now is 02:44 AM. |
