RCU Forums
-   Electric General Discussion (https://www.rcuniverse.com/forum/electric-general-discussion-106/)
-   -   No throttle & ESC not entering programming mode (https://www.rcuniverse.com/forum/electric-general-discussion-106/6487657-no-throttle-esc-not-entering-programming-mode.html)
alrdye 10-14-2007 01:41 AM
Hello, I'm building an eflight foamie so I purchased an ar6000 receiver, a thunder power 1320 mAH LiPo battery, an e-flight 25 amp brushless ESC and an e-flight 400 brushless motor. I put deans connectors on the battery and ESC battery leads.
After getting the leads soldered on, I hooked up a y harness to the ar6000 and bound my dx7 to it. I then removed the y harness and and tested my servos and they all checked out. Next, I hooked up everything to test my motor and program the ESC. My problem is that I can't get my ESC into programming mode. I've read and reread the instructions but to no avail. Also, even though the throttle servo connector on the ar6000 works great, I get no throttle via my ESC to the motor. I've rebound my dx7 several times and re hooked everything up making sure I didn't miss anything but with the same results.
Any ideas of what else I might try? I'm hoping this isn't a defective ESC because I already put a dean's connector on it but that seems like the most logical possibility to me. But then, this is my first electric system. I have a buddy who is into electric helicopters and has a pretty good handle on how this should work. He helped me double check everything and we are both stumped. He thinks it could be a defective ESC or motor.
Thanks for any help or ideas!
-Adam
Bad_Daddy 10-14-2007 01:57 AM
RE: No throttle & ESC not entering programming mode
Did you try putting the throttle on the WOT position for 5 seconds, then moving it back to the IDLE (off) position? Maybe your throttle channel is reversed, and you are actually moving to OFF for a few seconds then back to FULL.
Is your ESC plugged into the THRottle socket of the receiver (not the BATTery socket)? Is the polarity of the ESC / receiver connection correct? (Not the power, the 3-pin plug)
By the way, remove the propeller from your motor while you are playing with the ESC programming. No sense in allowing your plane to zoom across the room when you finally get it to work. :eek:
BarracudaHockey 10-14-2007 06:10 AM
If its a Futaba radio just reverse the throttle channel and try it.
alrdye 10-14-2007 09:03 AM
ORIGINAL: Bad_Daddy
I'm not sure what WOT is. I put it at both full throttle and no throttle, neither activated programming mode on the ESC. The ESC is plugged into the batter socket. I was afraid of plugging it into any of the others since it has power and I didn't want to blow any circuitry. Should it be n the throttle socket? I don't believe the polarity is reversed. I have it plugged up the same direction as the servos which seem to work, although maybe they'd work either way. Since this is my first electric there are many unknowns in my mind as to how this should be hooked up, what can be hooked up wrong and not damage anything and what can't be hooked up wrong without damaging something. [:o]
Also, the equipment isn't in the plane yet so I don't have the prop on the motor yet. ;)
ORIGINAL: BarracudaHockey
My controller is a spektrum dx7 if that makes any difference.
alrdye 10-14-2007 10:31 AM
Follow up post, I posted this same question on another forum and found out that I should have plugged my ESC lead into the throttle socket rather than the battery socket. Its all working now.
