Failsafe help
Hi,
I have aquired a S.M. Services On-Board Failsafe. Where does it go? Between the ESC and receiver? Andy |
RE: Failsafe help
I think so, it makes sense, but i'm not really into electric
RE: Failsafe help
I think you can put it there or between any of your servos and the receiver. If you put the failsafe between the receiver and the esc, it will only work for the throttle.
RE: Failsafe help
The S.M. unit can act as a failsafe for whatever channel you wish. I've never used a failsafe system, but I believe you normally use it with the throttle.
- Jeff |
RE: Failsafe help
Thanks lads,
I'll give it a go. Andy |
