Coupling Motor-Controller-Receiver
Hi all,
I've to select receiver and speed controller for the 480 motor of my P51D Mustang, but i've to ask your help about a few things: 1) I assume that the 480 motor is of the brushed type, i'm right? 2) then which kind of speed controller do i need? 3) may i use whatever 4 channel receiver or do i need to verfy compatibility between motor, esc and receiver? Many thanks to you, Giuseppe |
RE: Coupling Motor-Controller-Receiver
Need more info on the "480" motor. If it is the E-flite 480 it's brushless which affects all the other answers.
WT |
I am sure you will need European frequencies in your RC gear. Not sure about using USA servos or ESC's. When in Europe use Europe equipment. Rich |
Many thanks for your reply,
i've no info about the motor because it's factory-equipment for my ready-to-fly park-zone mustang, but given the price of the entire model (150 Euros), i assume that the motor is as cheaper as only a brush-type 480 motor should be... About the frequency issue i understand that i've to go into european Mhz band, but do i need to comply with Ampere requirements or similar stuff for selecting a receiver and a speed controller? Regards, Giuseppe |
@Giuseppe
As for RC frequencies and electric flight in Italy, you could ask http://www.baronerosso.net/forum/ You have some basic questions. Do you have you experience with other RC planes? If not, I seriously doubt if you should start your career with a P51. Vriendelijke groeten ;) Ron van Sommeren • int. electric fly-in, Nijmegen, the Netherlands • brushless motor building tips & tricks • diy brushless motor discussion group • Drive Calculator download & discussion group |
| All times are GMT -8. The time now is 01:38 PM. |
