RCU Forums
-   Electric General Discussion (https://www.rcuniverse.com/forum/electric-general-discussion-106/)
-   -   superbright leds??? how to install???? (https://www.rcuniverse.com/forum/electric-general-discussion-106/7995977-superbright-leds-how-install.html)
idivein 09-27-2008 12:02 PM
i bought superbright leds. how do i hook them up and attach wires where? i don't know series or parallel. please help. diagram would be perfect. thanks
Sir Raleigh 09-28-2008 08:09 PM
RE: superbright leds??? how to install????
This site will help you: http://led.linear1.org/led.wiz
-pkh- 10-02-2008 01:17 PM
You have to put in a series resistor to limit the current. That link Sir Raleigh posted looks like a convenient calculator to use in figuring out the right value.
The LED should spec a voltage and current for proper operation. You have to drop the rest of your source (i.e. battery pack) voltage across the resistor. R=V/I, where R is the resistor value, V is the voltage you must drop across the resistor (source voltage minus the LED voltage), and I is the LED current. If you have multiple LEDs of the same type, you can stack them in series with the resistor as long as the sum of the LED voltages is less than your source voltage. Then the V in this equation becomes the source voltage minus the sum of the LED voltages, while the definitions for R and I are the same.
