GP 12-amp ESC
I was wondering if i could change the BEC on the ESC to go higher if not what do i do.
RE: GP 12-amp ESC
If your receiver and servos need more current than the ESC's BEC can supply, you have 3 choices.
1. Switch to a different ESC with a BEC that can provide more current. 2. Disable the BEC in the ESC and use a separate battery for the receiver and servos. 3. Disable the BEC in the ESC and use a separate standalone BEC. - Jeff |
| All times are GMT -8. The time now is 12:12 PM. |
