RCU Forums
-   Electric General Discussion (https://www.rcuniverse.com/forum/electric-general-discussion-106/)
-   -   running BL motor without RX & TX possible? (https://www.rcuniverse.com/forum/electric-general-discussion-106/8736764-running-bl-motor-without-rx-tx-possible.html)
lotaloi 05-03-2009 12:39 PM
Guys,
I'm new in this electronic section.
I was looking for a device which can run a brushless motor without the need of a radio and receiver. I just wanna hook up the *device with the ESC,and wanna increase or decrease the motor speed. Usually a radio system hooked up with ESC does this job. Anyone of u used this device or know any of that serve my purpose?
http://www.hobbycity.com/hobbycity/s..._Servo_Tester_
Red Scholefield 05-03-2009 02:38 PM
RE: running BL motor without RX & TX possible?
ORIGINAL: lotaloi
Guys,
Almost any servo tester will do what you want. I have one from Astro Flight that is invaluable in setting up a plane without using the transmitter or receiver.
DaveFlynn 05-03-2009 02:47 PM
A servo tester is a good solution. All the ESC is looking for is a positive going pulse between 1 and 2 milliseconds about every 20 milliseconds. You could even build your own with an LM555 timer.
Gulliver 05-03-2009 03:08 PM
Make sure you set the sevo tester to the low end before you plug in the motor or be prepared for a speed bust.
Bozarth 05-03-2009 07:02 PM
I use a Ztron c/l timer. You can set when the motor turns on, how long it runs, at what power setting, ramp ups, and shutoff warnings (blips).
Kurt
-pkh- 05-04-2009 10:44 AM
1 Attachment(s)
Here's a servo tester/cycler I have. Should work fine with an ESC & BL Motor:
http://www.york-electronics.com
Dr Kiwi 05-04-2009 11:07 AM
http://www.gobrushless.com/shop/inde...ef=SERVOTESTER
lotaloi 05-04-2009 02:03 PM
Guys,
Thank u all for ur kind help. Keep posting. It's a new device I've ever never seen, but wished it exist;finally that does exist. Cool!!!:D provide the URL where u got that stuff from as well.
Copyright © 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
