RCU Forums
-   Electric General Discussion (https://www.rcuniverse.com/forum/electric-general-discussion-106/)
-   -   Question on Program Card (https://www.rcuniverse.com/forum/electric-general-discussion-106/9957160-question-program-card.html)
Motorhomer 08-24-2010 03:59 PM
I'm using a Program Card from Turnigy for my Turnigy motors. I don't know what to do on the "Timing Mode" (Low, Middle or High) and the Govenor Mode (Off or On)? Can any one explain this so I can program my ESC's? Many thanks, Ken McCormack
BarracudaHockey 08-24-2010 04:09 PM
RE: Question on Program Card
Governor mode is for helicopters.
I can't remember setting any that weren't MID timing though if I try to explain it I'm sure I'll botch it.
jzrf6c 08-25-2010 09:35 AM
I've had to change the timing on several Turnigy motors after setting the Throttle range. The problem I had was the motor would screech.
So, I'd say if you have an issue try changing the timing to see if it helps.
BarracudaHockey 08-25-2010 10:06 AM
Depends on when its screetching.
If it's doing it with fast throttle changes, some cards have a throttle response setting that will fix that as well.
Motorhomer 08-25-2010 12:43 PM
Thanks guys, I appreciate your input. Ken
DaddySam 09-02-2010 10:06 PM
I've ordered one of these cards to program my Turnigy esc's so this is good information. I'm using mine on a HK500 electric helicopter. Will I be able to program a "soft start" mode, if if so what does it do?
Thx
Sam
