Electric Indoor & Micro RC Flight Talk about this fast growing niche in rc. Micro radios, micro electric or co2 powered planes, heli's both indoors and out.
prop saver bands?
Old 03-10-2013, 04:31 AM
FASTCRASHER's Avatar
Default prop saver bands?
I just flew my first elect plane yesterday = the pop wing from Nitroplanes , my problem is every time i land it the freeking prop pops off ,(maybe why there called pop wings ) and iv lost my black prop saver bands to hold on my props...can i use reg rubberbands or does anybody have a better way to do this?
Old 03-10-2013, 08:18 AM
Lnewqban's Avatar
Default RE: prop saver bands?
Unless you can stop the propeller in the horizontal position just before each landing, your prop is going to pop off, in order to save the weak shaft of the motor.
O-rings are ideal, but you could use regular rubber bands if they give enough to release the prop upon impact and strong enough to keep the prop attached to the shaft at max rpms'.
You could also build some protection for the prop not to touch the ground, made out small piano wire.
Old 03-10-2013, 09:12 AM
thanks Lnewqban ....O RINGS ,DO YOU KNOW WHAT SIZE?
Old 03-10-2013, 09:27 AM
Lnewqban's Avatar
Here it is:
http://www.himodel.com/electric/T-Mo...ess_Motor.html
12 mm diameter O-ring x 2.0 mm thickness.
Old 03-15-2013, 12:55 PM
Go to your medical supply store and get a few ft. of rubber pipe called Theraband. It's used for stretching exersizes for therapy. Slice it up with scissors or a knife about 1/8 in. long. These rubber bands will work much better than the neoprene rubber O rings.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
