9x Tx woes
9x Tx woes
I have this Tx module, http://www.hobbyking.com/hobbyking/stor ... dule_.html installed into a HK 9x transmitter
and am trying to get it to run this, micro Rx/servo combo
http://www.hobbyking.com/hobbyking/stor ... duct=18821
I have all the switches in the Tx module set at off. I have the stick mode set at 3, for rudder and elevator driven by the right hand stick for an airplane with no ailerons. That part works great.
The problem is, the rudder stick drives the brushless motor and the throttle stick drives a servo plugged into either of the servo outputs.
No combination of stick mode on the Tx and switches at the back of the module can correct this.
I have spent several hours and am stumped.
FYI, I'm pretty much a Newbie with electrics.
