powerplant advice
PA
I am converting a formally rubber powered model to a 3 channel electric r/c micro flyer. The airframe will need to be modified for strength and for electronics, a neat little project. Cant wait to see how it turns out. The model is micro sized with a 24 inch wingspan. High wing, good dihedral, and flat bottom aerofoil - like a miniature trainer.
I am new to electric r/c so my main questions for you electric gurus are: what is an ideal powerplant for this model? Three channels means it will have ESC, rudder, and elevator. I was thinking 180 sized but am unsure on battery size or type. NiMH or Lithium? Current rating? Geared or direct drive?
thanks in advance
thanks in advance
Unless you want one heck of a fast model, go with the RFFS. at 100$ USD it's pricey, but worth it. It has 3 channels, and a biult-in ESC/BEC. It is designed to run on one LiPo cell (~8.00) and is used often with N20 or pager motors-although many have had success with the E-chargers powerplant. for 15$ extra, they will throw in two actuators-and 115$ for a reciver (GWS pico, 30$), two servos(CS-6.2, 20$ apiece) a speed control (20.00 for the ICS-50 E) is'nt a bad deal.
Of course, you could always go IPS/pico/cirrus, but that would give you one heck of an acrobat with a 24" wingspan, so be ready to fly FAST.
If this is your first plane, go with foamfly.com's frog-only about 20.00 for a few sheets of Depron (bluecor works great if you can get it, and it's cheaper) and a bottle of Gorilla Glue (no CA for me, thanks). Although the motor is not included, you can save some weight and increase efficiency by upgrading to a IPS orbital aftermarket gearbox, wich is about the same as the reccomended IPS A.
Just my two cents.
-joe
Just my two cents.
-joe
