DWE Widget Hop-up
Hi,
After succesfully flying my DWE Widget outdoors using traditional R/C conponents like servos and a GWS, I managed to crash it twice while trying to fly it indoors. It was simply too heavy!
To lighten up my Widget, I used two magnet actuators and an RFFS100 module from [link=http://www.smallrc.com/dwehtml/iemicro.cfm]Dynamic Web Enterprises (DWE)[/link].
My 1.7oz Widget not only can fly indoors now but it can fly in a very confined area in my own backyard!
The magnetic actuators easily mounted in holes that I cut into each side of the frame.
The control surfaces are then linked with carbon rods using solid wire ends in a "Z" bend.
Since I was initially a bit tail heavy and my foam elevator warped easily, I "killed two birds" by making a balsa elevator. Even on foam models, the lighter and stronger balsa wood makes a superior control surface.
An inside view reveals the magnetic actuators, Azarr antenna, and my plug-n-play charging unit from the Lightning (aka Micro Taxi).
The single DWE 230mAh cell is mounted up front just behind the front wall.
