HELP adding rudder to IFO MK 3
My Feedback: (28)
NY
I want to add a rudder to my IFO MK 3. I am in the construction process at the point of adding the rudder. Has anyone added a rudder to it? I see the Trainer IFO has a rudder but can not see how it is attached.
I thought of using the 1/8" tubing supplied and mounting it vertically in the right aft corner where the fuse stick meets the training edge. Then add a third servo behind the 2 that are already there.
ANY suggestions would be helpful.
Jeff
Jeff
RE: HELP adding rudder to IFO MK 3
My friend built my IFO with a working rudder. It makes flying the IFO more fun. At high angles of attack the IFO has some adverse yaw that you can't control if you don't have a rudder. The IFO will turn nicely with just the rudder.
Tennessee Flash
Tennessee Flash
