Looking for brushless setup for IFO MK3
I have been trying to figure out what to use for brushless setup on my IFO MK3 and also my Mini IFO, I want it to be ballistic and have plenty of power for vertical flight and hovering I plan on putting a rudder on my MK3, Someone has suggested using a 300 gearbox with a himax but what ratio do I want, and which himax, how many amps does my ESC need to be, I guess I will use a 1047 propeller or something similar.
NY
I'll be checking...Good luck
Any small brushless with a kv of 3-4000, give or take, geared around 6 to 1, will swing a 10-12 inch prop on 2 lithium polymer cells, and easily take a MkIII vertical. I've used Razor motors, Astro 010s, etc. For the Mini, a PJS300 or Nippy 0508 outrunner will do it, or one of the newer CDRom based motors, all direct drive, also on 2 cells. The extra power causes frame flexing, and the extra speed causes tucking issues, so you'll have to make sure the frame is up to the challenge. I don't get to this site too often, but you might find examples with the search feature, as there are tons of brushless IFOs flying now. Best of luck!
MKH
MKH
How are you guys mounting outrunner and geared motors to your MkIII's. I rebuilt mine with 2 extra carbon rods next to the main bar (lengthwise) to give the servos something stronger to hold onto.
looking for suggestions...
