$16 micro r/c airplane
PA
I just made this micro rc airplane.
12in. wingspand
cost $16
I used all the radio gear out af a $10 rc car. i dont know if it will fly yet because i still need a prop(wich im going to get off a firebird outlaw).I hope it flys well. anythin i should do to it???I used sran wrap as coverning
IM 11 and this is my frist from scrach rc airplane.
I have a aerobird challanger and a firebird commander
12in. wingspand
cost $16
PA
ORIGINAL: hobbydawg
12in. wingspand
cost $16
12in. wingspand
cost $16
hate to tell you, but it probly wont go up. it should, on the other hand, glide with left and right, but its not gonna go up without a lipoly battery.
but thats a pretty darn nice plane[8D]
Benthehen
Benthehen
MD
hobbydawg,
Good work. I can help you with the prop. You can make one from the plastic of a 2 liter coke bottle. Cut a piece 1/4" x 1 3/4". Mark the middle and poke a tiny hole with a pin. Cut the prop shape and balance it using the pin in the middle hole. Now enlarge the hole so it fits on the motor pinnion (gear). Try poking with a pencil. Now hold the middle with plyers and twist each side in opposite directions. I have a control line plane using this type of prop. Check this thread for a video. Actually, in the video it is using a prop made out of thick paper and not my new prop. The new one works much better.
http://www.rcgroups.com/forums/showthread.php?t=276012
PA
i made a new one which i call the mini commander. it has a 12 in wingspand and can have up to 20 min flight times but it needs a bigger wing becaue it cant mat a lot of lift at slow speeds. right now it will fly but just glide no matter if the thotle is on or off.
