Electric Indoor & Micro RC Flight Talk about this fast growing niche in rc. Micro radios, micro electric or co2 powered planes, heli's both indoors and out.
Rudder on IFO
Old 09-27-2002, 05:02 AM
JohnW
JohnW's Avatar
Default Rudder on IFO
I just got a IFO and put two flights on it. It was a blast but the lack of rudder drove me nuts... back to the building room I went.
I modified my IFO such that it has a full flying rudder controlled by a third servo. It seems to work well and is quite durable. Makes TR possible, better tracking on vert lines, loops, and some interesting spins.
Basically, I took the stock rudder and put a vertical CF rod on it with about 1/3 of the area ahead of the rod. This rod became the pivot/hinge of the surface. I then glued some large nylon tube about 1" long (extra from kit) vertically where the fuse mast meets the trailing edge of the wing. The vert CF rod on the rudder slides into this tube and is kept captive by a extra servo horn that is glued to the CF rod which also acts as the control horn for the rudder. I moved the RX forward a little and put the rudder servo just behind the RX to avoid moving the CG too much. I figure the entire weight penalty is one servo and about 6" of CF rod and a little glue. I can get almost 45 degrees of throw before I start to interfere with the elevons.
Sorry I don't have pics. Might try to post some later if anyone is interested.
Old 09-27-2002, 09:39 PM
Johnny9390
My Feedback: (34)
What bettery are you using and how much flight time do you get on it..
Old 09-28-2002, 02:19 AM
jmulder
Yeah Id like to see some pics of that.................John
Old 09-30-2002, 02:46 AM
rcairmike
My Feedback: (19)
pics would be nice,is this the mini or m3
Old 10-01-2002, 05:16 PM
JohnW
JohnW's Avatar
Default IFO
rcairmike: It is the MK3, my guess is the mini won't like the extra weight, but don't know... don't have one.
johnny9390: Using a 3 cell Lithium Ion pack from WildRC. I get about 20 minutes of air time and I have better than 1:1 for about 1/2 the filght.
To all: Have photos developed. Will scan in tonight and post if I have time.
Old 10-01-2002, 06:52 PM
Johnny9390
My Feedback: (34)
I really like the idea of those lithium packs but they are SOOOO expensinve, especially if you gotta buy the charger and power supply.
Old 10-02-2002, 01:54 AM
JohnW
JohnW's Avatar
Default Pics
Johnny: Yes, the Li-Ion packs are really light... you can really feel the weight savings... especially in the pocket book. Reguardless of the cost, I really like the packs... light and long run times.
Pics of rudder follow.
Old 10-02-2002, 01:55 AM
JohnW
JohnW's Avatar
Default Bottom View
Bottom of rudder, hings post and rudder servo w/ pull/pull lines.
Old 10-02-2002, 02:41 AM
rcairmike
My Feedback: (19)
well i decided to get the t-ifo,will take out the dihedral add the elevons-this way the rudder is there already-thnx for pics
