Hacker A20-S Shaft Position
I posted this in the Brushless forum, with no response, so I thought I'd try a more general forum.
I have a new Hacker A20-S, going into an Epic foamy. I've always run AXI in the past, but thought I'd experiment after hearing some good things about this motor. However, I thought I would be able to switch the shaft position (which end it sticks out of) on the motor, but can not see how this can be done. I've removed the C-clip on the shaft, loosened the set screw, and the shaft can be removed with some steady force. BUT - how do you change the position of the shaft without leaving the C-clip off? Or is this okay? I know some motors can be pulled apart normally, and seem to hold together during flight with just the force of the magnets.
I saw a couple of posts relating to this, but none were very clear; they mostly focused on problems with actually getting the shaft itself out, which I can do. Suggestions would be appreciated [&o]
GA
RE: Hacker A20-S Shaft Position
You might contact HAcker directly, but I do not beleive there is a way to move it and still use the clip......
I would bet it would hold without the clip, but I cannot say for sure...
Actually, Hacker supplies a wheel collet with the motor, and you use this instead of the C-clip. Silly, really when they could just include a second shaft with the clip position moved back on the shaft. However, the wheel collet works with the shaft pushed through for mounting the motor the other way around.
Tim
Tim
