Backyard Evil
PA
Backyard Evil
Been so busy latley making motors that it's hard to get away to fly.
Need stuff to fly out the back door, bug the cats.....
So I took two of my earlier designs mated them (in a evil way) and then shrunk the result to get a 18" wingspan, full house control balenced on the centerline kind of thing. Oughta be fun.
No sure if I will kit it or not, but it should be light. That's a 22.7mm GB motor hung up front. Figure a 450 3S and a 5" prop 15 or 17T
Meet Darth Trix
Meet Darth Trix
PA
RE: Backyard Evil
PA
RE: Backyard Evil
Got the laser sheets from Littlebirdz.
Still need a bit of work on the fuselage
And some recomendations on flight gear. I already have a 12 gram outrunner with 5 3/8 oz of thrust.
PA
RE: Backyard Evil
Ordered the following gear this morning
3-Blue Arrow BA-TS-3.6 Micro Servo with With JST Connector
Blue Arrow R3P4-J II 3.8g Receiver
Generic UM5 Receiver Crystal Channel 31
Micro Z-72 Antenna
E-TEC Lithium Polymer 7.4V 450mAh HP
Micro Z-72 Antenna
PA
RE: Backyard Evil
It's comming along, still working on the fuse details.
I find that working partially on the bench and also in CAD helps be visualize the design better.
