Electric Indoor & Micro RC Flight Talk about this fast growing niche in rc. Micro radios, micro electric or co2 powered planes, heli's both indoors and out.
Aero Ace build Qs
Old 06-19-2006, 08:10 PM
makg's Avatar
Default Aero Ace build Qs
Hey guys, I have a guillows plane (actually three made into one P-38) And I was wondering how light it HAS to be with out the aero ace electronics in it, I also need to know how i can make the engines pull, without switching the wires around. Thanks
Old 06-19-2006, 08:12 PM
monstermaker13's Avatar
Default RE: Aero Ace build Qs
you have to swich the wires around to make it pull
Old 06-19-2006, 08:45 PM
makg's Avatar
Hmm, i thought i heard microbuilder say that you could pull a prop of one engine, flip it around and put it on the opposite engine and vice-versa...
Old 06-19-2006, 08:48 PM
he did? i guess i must have missed that.i opologise
Old 06-19-2006, 09:45 PM
makg's Avatar
I just confirmed that you can switch the props (right to left, left to right) and it works great!
Old 06-19-2006, 09:56 PM
Seek and Destroy's Avatar
that makes it easier!!!!
Old 06-19-2006, 10:31 PM
micro_builder's Avatar
yep, just flip and switch the props (i learned that the hard way!)
as for the weight of the plane, consider the AAs electronics weigh in at around 10-12 grams. the motors can put out about 10 grams of thrust, so you should be able to get away with an airframe weight of around 10 grams.
the general rule of thumb, is that the thrust should be around half of the weight. i.e. 10 grams of thrust should carry 20 grams of weight...this is very general though, lots of other things that can change that. only one way to find out of the motors will pull it along!
if all else fails, you could put in some larger motors, like the SuperSlick 7mm motors that are sold at Toys R Us. they'll draw more current, so you might need a larger cell, but it would certainly give you more oomph.
nick
Old 06-19-2006, 10:41 PM
you have to switch the motors around too, right?
Old 06-19-2006, 11:57 PM
makg's Avatar
im not sure....
Old 06-20-2006, 12:06 PM
i'll ask him................sometime.
Old 06-20-2006, 12:52 PM
no, just the props like he said
Old 06-20-2006, 04:25 PM
makg's Avatar
ORIGINAL: rc18t145
Now I see what you're saying- No, you do not - just swich propllers around
Old 06-20-2006, 06:03 PM
cool[8D]
Old 06-21-2006, 07:01 PM
Neurotex's Avatar
ORIGINAL: makg123
ORIGINAL: rc18t145
If only just. The props are on pretty tight. I had to make a puller
to get them off without possibly bending the shafts. But that's the easy
part compared to pushing them back on. My first attempt ended up in
me pushing the shaft through the back of the motor. It was locked up
but I fixed it by pushing it back through with the end of a small drill bit.
It works even with the hole in the back.
The second attempt went better as I used the drill bit to brace the bottom
of the motor as I pushed the prop on. After a test there was rear thrust
but the props were still on wrong.
I finally got it after micro pointed out the error. Try it. FUN!!
Also, what kit did you get?
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
