Storm Launcher!
#101
AK
RE: *!STORM LAUNCHER!*
That is totally awesome... Are they Decals? Do they come with the SL? You need to take some more pictures...like of the elevator and linkages, motors, battery compartmant-that would be super cool
#102
TX
They are Home Made decals hand cut from Monocoat trim sheets. The stock Hydro comes with decals like in the pic below. I wanted a sample with the black and yellow decals, didn't get it , so I came up with my own. I think mine looks better any way
#104
TX
ORIGINAL: makg
Yup they sure do...Will extra props be available for sale at target, wal-mart, ect?
If enough get sold, there may be some independent supplier that might carry parts, like some do for the Aero Ace. Basically all they do is buy a bunch at one time, then part them out.
#109
TX
ORIGINAL: W.A.S.P.S-Flyer
do the tail fins break easily?
With out the Horizontal. It loses a little of its self recovery out of a dive and a small bit of lift, because then the elevator requires some up trim, but the elevator becomes much more effective since it's not deflecting its air into the upper horizontal at full deflection. So it's easier to perform loops and has more crisp sharp turns.
With the horizontal removed it also makes the vertical easier to break, though the foam does has a skin and its pretty tough. Can be easy fixed though if it does break with just some clear tape or Hot Glue.
You can always cut new ones and experiment with different shapes and sizes. Makes it handle different , sometimes better in some ways , sometimes worse.
#111
CA
Is the storm launcher fully waterproof? So if you land on it's back in the water it won't break...? And how many channels is it? And I see you need to buy the lipo battery seperate [:@].
#117
TX
indeed, one channel per motor. i was just making sure i hadnt misread something and that both motors were on one channel, and the 2nd channel was for a rudder (that didnt make sense to me).
#118
TX
ORIGINAL: monstermaker13
would it be ok if i removed the false exhaust vent? {the cone looking thing on the back}
Really becomes quit zippy with longer flight times if you do all the above, doesn't look all that great though
#119
TX
Its easy to modify to use your own battery , as long as it doesn't weigh much more than the stock battery ( 50 grams). Even after you modify it you can still use the stock battery.
Remove the pins inside the boat ( to the right of the pic), solder on your own battery connector. Then solder a plug on the pins that you removed and plug them back into the battery (left of pic). Then you can charge it with your own charger or the Air Hogs Charger (recommended because it's a balancing charger). Plus you can use your own battery or the stock one.
The battery is clearly marked with molded in positive and negative signs, it just doesn't show up in the pic. Should have colored them for the pic.
#120
AK
Hey UAV Pilot: Can you take some more photos of the SL? Like of elevator, motors, battery comparment, ect? That would be great if you could
#121
TX
ORIGINAL: makg
