Go Back  RCU Forums > Electric Aircraft Universe > Electric Indoor & Micro RC Flight
 Well I just ordered my electronics for a homemade micro >
Electric Indoor & Micro RC Flight Talk about this fast growing niche in rc. Micro radios, micro electric or co2 powered planes, heli's both indoors and out.
Old 06-26-2006, 07:59 PM
Default Well I just ordered my electronics for a homemade micro
I just ordered what I believe should make a reasonable micro.
GWS EDP-50XC (60grams thrust)
GWS ISC-100li (4a lithium esc)
GWS P4pII Reciever(4ch)
Cirrus 5gram servo(x2)
500Mah 7.2v lipo
I expect the all up weight to be somewhere between 2 and 3 ounces, wich will fit good with my thrust.
I'm trying to find a reasonable and durrable design. I'm looking to keep the prop safe so maybe something like an aerobird. Or a Bi-Plane with the prop in the middle between the wings. My aim is to proabably get flight speed something in the range of an aero ace or a bit faster.
Most the the equipment was a balance between price and weight.
Old 06-26-2006, 08:11 PM
monstermaker13's Avatar
Default RE: Well I just ordered my electronics for a homemade micro
talkto microbuilder. he has lots of plans. or go to my post,airhogs tri fuision and i have plans for a micro hydrofoam.
Old 06-27-2006, 06:04 AM
andrewtexas123's Avatar
where did you get your supplys
Old 06-27-2006, 11:52 AM
Seek and Destroy's Avatar
probably at bsdmicro.com
Old 06-27-2006, 02:31 PM
most of it came from aeromicro.com all except battery.
Old 06-27-2006, 04:39 PM
micro_builder's Avatar
i'm not familiar with a lot of pusher setup style planes. but, you could make a smaller version of the Stryker F-27 (assuming you can do elevon mixing on the RX or TX). if you do a search here on RCU for "pusher" or something similar, it'll probably give you some results for some good planes to go off of. let us know what you come up with.
nick
Old 06-27-2006, 05:09 PM
I'm working out the details now for a Bi-Plane with the motor and prop inbetween the wings. I also have this crazy urge to order another servo to adjust the angle of attack for the wings. I think in such light loading I could pivot the wings at the leading edge somewhere pretty easily with a small servo. I could have a nice easy slow flyer and adjust the angle back flat for fun fast flight.
I just having to figure out if its a crazy idea that is good or bad.
Old 06-27-2006, 05:28 PM
that sounds pretty cool can wait to see the turn out
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
