Electric Indoor & Micro RC Flight Talk about this fast growing niche in rc. Micro radios, micro electric or co2 powered planes, heli's both indoors and out.
Giant mono-wing
Old 08-11-2006, 02:12 PM
Default Giant mono-wing
If i get another AA bipe, im going to take lower wings, and put them on the top wing with some dihedral and then im going to take another set of bottom wings from my lost AA and then add those! But first, Ihave to save $30 for another AA[][:@][&o]
Old 08-11-2006, 04:45 PM
monstermaker13's Avatar
Default RE: Giant mono-wing
why dont you get posterboard. soak it in water for about an hour. scrape off the paper. and then make a big 48 inch wing :] i personally like making my own wings. {not saying that i put wings on my arms and jump off a roof!}
Old 08-11-2006, 04:59 PM
makg's Avatar
ORIGINAL: monstermaker13
my dad did that once...lol
Old 08-18-2006, 11:50 AM
Well i think im gonna get another AA to day and im going to try it out! Ill post back with results on sunday possibly
Old 08-18-2006, 02:56 PM
Neurotex's Avatar
I found a sign at work that has the foam pressed between card stock and it's
been soaking now for 12 frigg'n hours and that paper still won't come off.
monster! I'm finding you a nice tall roof![>:]
edit: Finally managed to scrape all the paper & glue off this thing. Ended up with
a tub full of glue and moosh. [sm=drowning.gif]After straining all that gunk out I had a nice piece
of foam. Worth it-
so I'll look for a nice small roof [sm=biggrin.gif]
Old 08-20-2006, 04:14 PM
Well i tried it out. it was a little breezy so it was almost impossible to fly good. I launched it into the wind and it started climbing faster than i thought an AA ever could! It was preety much uncontrolable and i almost lost it a couple of times[X(] As of now, it only has one set of bottom wings on the top wings and it flies awsome! I might try to build a delta wing because i want to go fast and handle the wind better[>:]
Old 08-20-2006, 04:38 PM
ORIGINAL: Neurotex
of foam. Worth it-
was the board skinny or thick? i use the thick kind. i just soak it and scrape the paper off with a dish scraper.not as hard as you say it is. cheaper that buying foam from depron usa. really worth it. im going to make a big "ornithopter" soon. one wing is going to be made out of one sheet of posterboard foam. its gonna be big.like a 6ft wingspan!
Old 08-21-2006, 01:11 PM
Neurotex's Avatar
I think this was manufactured different than what you mentioned. I believe
what you have I've seen at hobby shops with the thin paper covering.
This thing had thick glossy card stock on both sides and under that there was
a plastic film that I also had to peel off. After all that the foam was 4mm.
If it wasn't for your post I would've chucked it, so at least I did end up with a
good piece of usable foam.
Post some pics of your ornithopter when you get it did'
Old 08-22-2006, 04:54 PM
i tried this myself and you definetly need some struts or something to hold the wing. Whenever i flew it the wings curved up so much it looked like i was flying a giant U. Then when i tried to turn it would go into a death spiral to the ground. for this plane to work you'd need fins in the wing or a tail that is bigger and farther out.
Old 08-22-2006, 07:31 PM
ya, it did seem real tipsy on the pitch axis.
Contact Us - Manage Preferences Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
