micro hughes 300
CA
micro hughes 300
hi all,
very new to the new micro scene. can I make any changes to this helicopter. it was given as a bday gift and know nothing on it. heres a pic and vid
http://youtube.com/watch?v=j52s9Zog9SU
RE: micro hughes 300
It is a PicooZ copy, so you shoud be able to do the mods you can do to the Picoo, to that. Check here -> http://www.rcuniverse.com/forum/m_4346407/tm.htm there is tons of mods there.
Several have made mods to the Picoo so it would look like this (inverting main gear assembly, adding body, adding extra main shaft supports, etc) and now it's already done for you. Your bird has alot more power than the Picoo so it will take some practice to master it, especially on a full charge. I see yours has red skids and tail motor mount, so which channel is it? Mine is molded in white and runs on channel C. Did you get it at Fry's for $21?
