CESSNA 210 WING REMOVAL? Help!
Have to get below the wing to see why the rudder servo is not not working and making noise. Anyone know how to get inside. It could be a wing removal or decal removal and split body. Ron
RE: CESSNA 210 WING REMOVAL? Help!
Your right Tim! You cut off the decals and the body opens. Looks like the servo design is poor in my opinion. The servo works with a screw through a plastic piece which the servo wire connects to. The metal screw strips the plastic piece and no more servo. The screw is turned by a small motor which strips the plastic when conditions are right. This one stripped on a light landing with a straight in prop hit. Ron
