Go Back  RCU Forums > Electric Aircraft Universe > Electric Indoor & Micro RC Flight
Reload this Page >
Hitec Feather Antenna ...Help....
Electric Indoor & Micro RC Flight Talk about this fast growing niche in rc. Micro radios, micro electric or co2 powered planes, heli's both indoors and out.
Old 03-13-2003, 03:19 AM
ml0126
Default Hitec Feather Antenna ...Help....
My antenna wire broke off of my Feather receiver. Even under a magnifying light I still can't find where it goes. In the attached picture, I know i goes in the bottom left hand corner. Any ideas on proper solder joint??????? Thanks
File Type: bmp
Old 03-25-2003, 11:34 PM
SelfMadePlanes
Default There it is!
It welds to the spot marked on the pic!
But be fery careful with the welding! The temperature should be somewhat almost excact to the melting point. And dont weld anything else to it. On the pic, the joinin spot is in good shape, try not to mess it up!
Go look for some expert if you arent too good at welding!
The welding goes to the black spot! Its small but find it almost in the bottom middle.
I really hope that you find the spot!
Old 03-26-2003, 05:59 AM
nitro joe
Just pulled the sleeve back on mine.
The wire is soldered at coordinate 153,133
Put a dab glue on the wires insulation after resoldering for strain
relief.
Old 03-26-2003, 07:32 AM
SelfMadePlanes
Default Missing?
The wire-holding-glue on your receiver is missing
Bad manufacturing?
