replacement propeller?
I have this little super sonic plane, flies great for what it is, but as usual, the propellers do have their limits.
Just curious if anyone might know of a source for universal props, seems I cant find any specific to this little plane, Ive tried the usual online sites, no luck, replacements are more available for larger planes, I dont have access to a local hobby shop either.
I cant offer the exact dimensions but I can say for sure, the prop is 2.750" long and the widest point on the blade is 7/16" and these are press fit.
Any suggestions appreciated, thanks.
A GWS 2510 or 2508 might fit the bill, if necessary they are easy to trim to reduce load on the motor ,their shaft size is 1mm,which is the same as most small motors(6 &7mm pager,M-20)
